586,065 active members*
4,638 visitors online*
Thread: G code error
Results 1 to 9 of 9
    May 2011
    65
    G code error
    Hi, very new to cnc so please be gentle, for my first project I did the instructural for the stepper plate, all went well until I tried to run the code, the machine started to position itself then I got an error saying "radius to end of arc differs from radius to startline 33". I have poured over the printout of the code but not knowing much about it I cannot find the problem. Can anyone point me to what I should be looking for?
    Thank you
    Terry
    Regards, Terry Howson
    Feb 2005
    521
    Hello Terry,
    Hopefully this will help...
    CamBam CNC Software - FAQ
    Basically the arc commands G2/G3 have two ways of passing the arc center coordinates (I & J).
    There is no "standard" way of telling in the g-code so you need to make sure the CAM and controller are using the same method.
    Mach3 uses a non-standard G90.1 and G91.1 command to tell which method is used, so using the Mach3 post processor will also help (if you are using Mach3).
    Good luck!
    Quote Originally Posted by skylanehku View Post
    Thank you
    Terry
    www.cambam.co.uk
    Jun 2007
    3757
    Post your code, and it will soon be identified, with a bit of luck.
    May 2011
    65
    Hi, thanks for replies, will try and post my gcode.
    Terry
    Seems I cannot post the file because it is an nc file?
    May 2004
    4519
    Either highlight the code and copy and paste it to the text box, save as a file extension TXT file and upload, or ZIP it and upload.
    May 2011
    65
    Will try to send file as zip.
    Terry
    Sorry that did not work either.
    Attached Files Attached Files
    As 10Bulls said, you need to change your IJ mode. You can do it in General Config, or add a G91.1 to the code like this.
    ( Made using CamBam - CamBam CNC Software )
    ( stepper plate 2 10/11/2012 5:51:44 PM )
    ( T0 : 0.25 )
    G20 G90 G64 G40
    G91.1
    G0 Z0.1
    ( T0 : 0.25 )
    T0 M6
    ( Pocket1 )
    G17
    M3 S1000
    G0 X0.025 Y0.0
    G1 F2.0 Z-0.02
    May 2011
    65
    Thanks very much Gerry, will give it a try.
    Terry
    May 2011
    65
    Thanks to all for your help, it was just as suggested, the mode for ij was checked wrong.
    Really appreciate your help.
    Terry
  1. error code 181 from a HPR 260. HELP!
    By rzapo in forum Hypertherm Plasma
    Last Post: Yesterday, 10:08 PM
  2. g code error with image to g-code
    By cruzin in forum LinuxCNC (formerly EMC2)
    Last Post: 09-05-2012, 11:34 PM
  3. Error code 104
    By morpwr in forum Haas Mills
    Last Post: 10-27-2011, 03:37 AM
  4. 004 error code
    By dek in forum Fagor Automation
    Last Post: 04-23-2010, 05:16 PM
  5. error code 017
    By musnar in forum HURCO
    Last Post: 10-13-2009, 02:20 PM
