586,590 active members*
2,671 visitors online*
    Sep 2003
    33
    Question Turning Aluminum 6061-T6
    I have been looking for the formula to get a starting point on my feeds and speeds on turning aluminum but haven't been able to find it anywhere. Does anyone know what it is?
    4826
    Yes.
    Find the circumference of your part. This might be a compromise on a lathe without constant surface speed, if the part has a wide variation in diameter.
    For High speed steel tools, I think 800 feet (of circumferential distance) per minute is acceptable, and with carbide, well, I don't know of a practical limit where you won't chicken out before the spindle gets going that fast
    The feedrate depends on the tool radius and chipbreak, as well as the desired finish: .010 to .020" for roughing, .005 for finishing. Its quite forgiving really, the most compromising on parameters is done to try to get good chip flow for the insert you're using.
    Sep 2003
    33
    Thanks man you've been a really big help. I implemented those and they worked great.
    Apr 2003
    1876
    Is that guy good or what!
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. aluminum extrusion
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 05-14-2013, 09:03 AM
  2. How strong? (Linear rails, aluminum structure)
    By WoodSnarfer in forum Mechanical Calculations/Engineering Design
    Last Post: 07-15-2005, 05:29 PM
  3. CNC Aluminum
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 02-12-2005, 04:39 PM
  4. In the same boat...trouble roughing aluminum
    By rc-cellar in forum DIY CNC Router Table Machines
    Last Post: 11-21-2004, 08:58 PM
  5. "shaping" aluminum?
    By smythe in forum MetalWork Discussion
    Last Post: 08-06-2004, 05:35 PM
