586,043 active members*
3,755 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Which motor and drive for g0704 spindle motor control
Results 1 to 18 of 18
    Apr 2012
    I have a g0704. I recently picked up a DMM Tech 3 axis 400 W AC servo kit to convert it to CNC.
    Unfortunately, before I got a chance to install it, the motor died. It seems like I'm not alone in having a dead g0704 motor. I thought I would take the opportunity to add control to the spindle of the mill. Fortunately, the breakout board that came with the kit has spindle control (see page 7 of the manual).
    My question is which motor and drive folks recommend. On Hoss's website, he recommended a GS2-11P0 1 HP 115VAC drive and a MTR-001-3BD36 1 HP 3600 RPM 3 phase motor. As he points out thought, the motor is huge and relatively low RPM.
    Is there a motor-drive combination that would deliver as good or better performance as the g0704 stock 1 HP motor for less than $500 (preferably substantially less than $500)?
    Thanks.
    Apr 2012
    I've done some more research and found that the MTR-001-3BD36 has a face diameter of about 7". I measured the space for a motor on top of the g0704 and found that the clearance between the spindle and the column could fit a motor with a face diameter no larger than 6.5".
    Any suggestions on a 1 HP, 220V, 3 phase (the drive takes in 115V 1 phase and puts out 220V 3 phase) with a face diameter less than 6.5" (preferably substantially less so that I can put a cover on the spindle)?
    Thanks.
    Nov 2009
    4415
    Why not use the treadmill motor as Hoss does?
    Might think about one of the 3.8hp treadmill motors with a kbmm-225.
    I just ordered a 3.8 on ebay to test out.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2004
    822
    The 3.8s work great. Much better than the 2.5s. I have been running one for quite a while with no problems. I don't have the PDB on in the photo but it fits fine.
    http://i457.photobucket.com/albums/q...4/6275c771.jpg
    Apr 2012
    Thanks for the suggestions. Your motor mount turned out well, mrcodewiz.
    I picked up a 3.8 HP treadmill motor from ebay. My concern with the KBMM-225 is that it is only rated for 2 HP at 220V. Is there a way to be able to tap into the extra 1.8 HP? I know it would mean a big amp draw (3.8 HP * 750 W / HP / 220 V = 13 A)...
    Jan 2012
    469
    "In addition, the rating of the control can be extended to 11/2 Hp at 115V and 3 Hp at 230V by the use of KB’s auxiliary heatsink."
    The extra 0.8HP I think you'd be out of luck for
    Jun 2004
    822
    I am using a KBMM125 since that was what I bought to go with the 2.5HP motor I used to have. Even so, with the 1.5 HP resistor and heatsink it seems to be way more than adequate.
    If you want, I can upload the Alibre files for the bracket that goes around the motor and the uprights. Mine is sort of hacky since I just tweaked the ones I originally made for the 2.5HP motor but maybe the measurements would be helpful.
    Jan 2012
    469
    Not that I've researched that much, but none of the eBay ads I found had an rpm spec for these 3.8hp motors.. Any ideas?
    Jun 2004
    822
    It's slower than the 2.5s. I want to say about 5k RPM but since I have the kbmm125, I'm only passing about 110 volts I believe.
    Jun 2004
    822
    Here are my Alibre files
    Attached Files Attached Files
    Apr 2012
    I ended up with a KBWT-112 given that the treadmill motor only goes up to 130V. Continuous 1.5 HP with an intermittent 2.5 HP isn't bad.
    mrcodewiz, thanks for the drawings. It's nice not having to start from scratch on figuring out how to mount the motor.
    Nov 2007
    980
    mrcodewiz, any chance these files can be converted to Solidworks type files?
    Possibly IGS or STL?
    Thanks for looking-
    Dave
    Dave->..
    Jun 2004
    822
    I have never exported from Alibre to STL so hopefully these work
    Nov 2007
    980
    Thank you sir, they look like they came through just fine-
    Dave
    Dave->..
    May 2005
    3920
    Quote Originally Posted by JeffsInventions View Post
    The failure rate for these motors is pretty massive. You almost have to plan on an update right off the bat.
    We use a bunch of these drives at work with almost zero problems. They are a very good value.
    There are other frame sizes you could look into. Don't forget that metric frame motors are fairly easy to get these days too.
    Thanks.
    DC motors and drives are relatively cheap but frankly I'd prefer an AC drive. Mainly because you don't have to deal with brushes and the price is more of a toss up these days. Your first goal should be a motor that mechanically fits on the mill and then buy a controller suitable for that motor.
    Frankly I'm not convinced that the motors on these Chinese machines are actually capable of producing their rated horse power for any period of time. It ought to be fairly straight forward to improve on the motor as almost anything you buy domestically will be of sounder construction and far better quality. Even used hardware will be better.
    Baldor has a nice motor size chart here: http://www.baldor.com/pdf/501_Catalog/BackCover.pdf
    Nov 2009
    4415
    codewiz, thanks for the file. I had never opened an STL in CamBam. That was cool.
    Apr 2012
    I also am looking to upgrade my motor fo rmy G0704. I would like the most HP and RPM for my 120V wiring where my mill is located. What motor and board options do I have. Thanks
  1. G0704 Spindle Motor Frame Size?
    By skynugget in forum Benchtop Machines
    Last Post: 09-02-2012, 06:03 PM
  2. Possible G0704 high speed spindle motor,
    By Turbo442 in forum Benchtop Machines
    Last Post: 06-25-2012, 09:33 PM
  3. Spindle drive/motor rpm.
    By hotrob1 in forum Fanuc
    Last Post: 03-15-2011, 10:18 AM
  4. DC motor drive control
    By jedcam67 in forum CNC Machine Related Electronics
    Last Post: 06-03-2007, 09:53 PM
