Howdy folks! I mostly lurk around here, but I have run across a problem with a part and I hope one of you fine folks will have run across something similar.
I'm working on the programing for this part using Mastercam Mill X4 MU3, mill level 2. It has two grooves inside of a slot that some wire needs to lay into... I'm planing to cut them with a full radius slotting cutter (as can be seen in the part file). Most of the segments are fairly straight forward, either with the center of the arc coinciding with the center of the part (and coincidentally the center of the rotation of my A axis) for which I can use axis substitution or in straight segments, so I can use axis positioning.
Near the exit however there are two radii which is where I'm trying to figure out the best approach. It seems like I should be able to use a 'true' four axis tool path to cut them, but I don't have access to Mastercam Multiaxis. Is there a way to cut that with Mill level 2?
I'm not worried about the "backwash" of the cutter etc. The tolerances are pretty loose and the piece is plastic.
For what its worth this is on a HAAS VF3 (vertical mill), and I'll be running the part myself.
Feel free to leave any feed back on the rest of the part too... thanks a bunch!!
Nate
