I need to machine a number of billet aluminum "Deadeyes". Deadeyes are the blocks you see on old sailboats used to adjust tension on the lines that hold the mast up before turnbuckles came along. The lashings require 4 holes with an arc on the X-Z axis for a fair lead. I am using D2NC and have to edit the g-code to change the working plane and add the radius. Errors in this edit have lead to some rather interesting shapes to say the least.
Can Cambam handle this?
