Originally Posted by
hndswthtshdws
To turn threads you just need a tool with a 60 degree angle. If you don't have one in your kit you can buy a HSS cutting tool blank for $2 and grind your own profile. You would hold it in of your two standard "turning holder" for your QCTP.
Your 2 standard turning tool holders for the QCTP are not going to be enough once you get some tools. Minimum you will want one for a left hand tool and one for a right hand tool. Those are the tools you will be switching between constantly. You will also want one for threading, one for finish cuts, maybe one for adding a radius to edges, etc, etc. You're fine for now but you will want more eventually.
Here's some things to consider about getting more tool holders:
-They are a super easy milling project. Don't buy 10 extra tool holders if you are planning on getting a mill in the foreseeable future.
-Tool holders are interchangeable between a lot of QCTPs. Find out what fits, its lets you broaden your search on ebay for a deal.
If you want to do any long skinny projects down the road you might need a steady rest and/or follower rest.
I would buy an assortment of HSS cutting tool blanks in a few different sizes. They are about $2 a pop. You can resharpen them with a bench grinder. You can grind any shape you want. They don't chip like carbide when you bump something you shouldn't have. I find myself grinding weird shaped tools all the time. I don't see the value in carbide in the home shop on import machines.
