586,121 active members*
3,373 visitors online*
    Oct 2012
    4
    Red face Enshu VMC 530
    Hi, I bought a used Enshu VMC-530 with an 11MA control. I believe the PMC parameters are corrupt. Does anyone have them in a file that they could send me? Also the control is asking me to "Please select switch lock release M code ! M** ?"
    Help!
    I could also use a copy of the machine operators manual.
    Henry
    [email protected]
    Jan 2011
    I may be able to send you an example set of PMC parameters to try. I'll try to email it to your address you provided.
    Also, If you cannot edit the keep relays on an Enshu with 11M:
    1. SET PWE=1
    2. PRESS E-STOP
    3. SET DATA PROTECT KEY TO “WRITE”
    4. PRESS “CYCLE START”
    KEEP RELAYS CAN NOW BE EDITED.
    On that Enshu, I think you may have to command an M80 to release the interlock for operation of the tool changer commands manually.
    Sep 2010
    10
    Hello everyone.
    I have also enshu vmc 1988 and I can send you parameters for that machine, but I have also problem.
    When I turn on machine it show me next alarms:
    SV013 INPROPER V_READY OFF (for all axis),
    SV014 INPROPER V_READY ON (for all axis),
    SV015 PULSCODER DISCONNECT (for all axis).
    Does anyone know what are the reason of those problems.
    Thanks.
  1. Enshu E130 Op. Manual
    By coalstove in forum Uncategorised MetalWorking Machines
    Last Post: 05-23-2021, 09:22 AM
  2. Enshu ! VMC 330
    By Camfather in forum Uncategorised MetalWorking Machines
    Last Post: 01-02-2020, 11:56 AM
  3. Enshu VMC-530
    By tjamscad in forum Uncategorised MetalWorking Machines
    Last Post: 08-14-2012, 12:48 PM
  4. Enshu 400 fav
    By uservitech in forum Uncategorised MetalWorking Machines
    Last Post: 11-30-2011, 04:27 PM
  5. ENSHU VMC40
    By RAMI in forum Uncategorised MetalWorking Machines
    Last Post: 07-06-2011, 04:35 AM
