586,114 active members*
3,376 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Hardinge Conquest ST-25 air leak main spindle
Results 1 to 2 of 2
    Feb 2007
    129
    We put a used ST-25 on the floor fired it up and things seemed to be OK. Then after removing the guide bushing (the #2 main spindle collet) from the main spindle to get to the main collet, the machine developed a massive air leak in the main spindle. It drains my 120 gallon air compressor in a couple of minutes and I haven’t been able to track it down. And ideas would be welcome thanks.
    Mar 2011
    27
    Quote Originally Posted by Big Daddy View Post
    Hi, there might be a problem with the air hoses in your guide bush. A small air purge is being done from the behind of gb while the machine runs to prevent oil leakage to the main spindle side.
  1. Hardinge Conquest 42 spindle question
    By rcpaisley in forum Hardinge Lathes
    Last Post: 03-01-2013, 05:24 AM
  2. Conquest 42 - Air leak heard from the spindle
    By MorueM in forum Hardinge Lathes
    Last Post: 09-13-2012, 04:05 AM
  3. Hardinge Conquest spindle question
    By rcpaisley in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2012, 04:06 PM
  4. Hardinge Conquest T-42 spindle will not rotate in jog mode
    By DannyP in forum Bridgeport / Hardinge Mills
    Last Post: 09-27-2011, 05:01 PM
  5. Max Spindle Speed in Jog - Hardinge Conquest T42
    By drunkendave in forum Hardinge Lathes
    Last Post: 05-07-2010, 04:38 PM
