586,042 active members*
3,804 visitors online*
Results 1 to 6 of 6
    Apr 2006
    40
    Does anyone use constant velocity mode?
    I like the idea of he machine trying to optimize its velocity, but can't see how it would really work in practice since you have no real idea what path it will take, especially if you have to make multiple passes with different bits and they may not line up. So in what cases do you use it and what precautions do you take?
    Cp
    Nov 2009
    4415
    I always use it. I also set my look ahead for 150-200 lines. Seems to smooth things out for me. I don't have any real criteria I have to meet but my own.
    A lazy man does it twice.
    I would think that nearly 100% of router users use CV mode. As long as you have decent acceleration rates, you shouldn't have too much trouble. Tweaking some of the CV settings should give you good results.
    Jun 2012
    ? Look ahead 150-200 lines how do you do that? Is this function available with mach3 or linuxcnc?
    Nov 2009
    4415
    Mach3 on the general config page. I run a mill.
    Dec 2004
    1865
    I only use CV on both the mill and the router.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  1. What is - Torque Mode? Position Mode? Speed/Velocity Mode?
    By sunmix in forum Servo Motors / Drives
    Last Post: 01-20-2024, 10:34 AM
  2. Constant Velocity problem with 4th axis
    By tiwanacote in forum Mach Mill
    Last Post: 03-20-2010, 02:25 AM
  3. Constant Velocity settings
    By Ranscon in forum Mach Software (ArtSoft software)
    Last Post: 09-03-2009, 01:08 AM
  4. constant velocity help
    By shnitzel in forum Mach Software (ArtSoft software)
    Last Post: 01-03-2008, 03:10 PM
  5. Constant Velocity Mode CONSTANTLY DIES!
    By backlashphoenix in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2007, 12:52 PM
