586,102 active members*
3,106 visitors online*
    Jul 2003
    126
    Stainless brackets needed 18GA
    I have a need for a custom bracket to be cut on either lazer, water, or plasma. It is then bent with 2 90deg angles.
    Length is 24" long with bends in this direction. First leg is about 1", middle about 3" and final about 1" forming a z shape (90 deg bends).
    In total is 5 holes (3 on one leg, 2 in middle section), the leg with 3 holes has corners notched.
    I have a DXF file I can email.
    [email protected]
    Need 10-20 pieces depending on price. Could use 2-5 ASAP.
    Jan 2006
    4
    Jeff,
    Probably a little late in responding to your post, but if not send your quote info to [email protected]
    Check us out at http://www.incodema.com , we are a state of the art
    prototype sheet metal forming/fab shop. We have an internet quote/order
    site and deal with customers big and small all across the US
    If you can dream it ... we can do it.
    Ben
