586,326 active members*
3,851 visitors online*
Page 1 of 6 123
Results 1 to 20 of 124
    Feb 2009
    118
    cnc vertical mill build log ( pics )
    Yo ,
    I needed a mill ... liked the PCNC 1100 from tormach , but is expensive ...
    so I decided to build my own , from scratch ... Design is very common
    ( so far I have seen several machines here almost identical ... ) .
    My english is not so good , so I will let pics talk for me ...
    All aluminum components were machined on my cnc router ( my last
    project , finished 3 months ago ) . First picture is taken in my shop ,
    reprezenting my cnc router .
    Here it is ...
    I stiil have a lot of work ahead , but I think I will finish this year .
    Components :
    THK SHS30CA rails , 80_80 aluminum extrusions , 1" thick MIC-6 aluminum
    plates , ISEL 2505 ballscrews on Y and Z , LeadScrewInternational precision
    ground 3210 ballscrew on X , Colombo RV110.22 / 10hp + Delta drive ,
    As for motors , I will use those weird hybrids from keling ... closed loop
    stepper motor kits ( 8N/m stepper motor , 1000ppr encoder , digital hybrid
    servo drive ) .
    I'll be back !!!
    Dec 2010
    again WOW!
    Apr 2009
    266
    damn that's gorgeous!
    my first..."Big Ape" CNCRP 2448 Build Log
    Feb 2009
    118
    Quote Originally Posted by kinghong1970 View Post
    Thank you .
    I assume that you are reffering to the vertical mill ... it's a work in
    progress , it will look much better at the end .
    If you are talking about the router , that's nothing ... I have an idea
    that's much better then this . AC servo , BT30 spindle with ATC , work
    table made from a single piece of aluminum ( 2" thick MIC-6 plate ) ,
    vacuum clamping sistem , 8 by 4 working area , Newall DRO ( just for
    fun ) , an so on ...
    Apr 2009
    266
    complete cnc nublet here so forgive my ignorant questions...
    you are making a gorgeous cnc mill mostly out of aluminum, right?
    how rigid and strong is this... or how does this compare to a equivalent sized machine made of cast metals and steel in terms of performance?
    thanks in advance,
    Al
    Feb 2009
    118
    thanks in advance,
    Al
    I have no idea ... but I also have no posibility to work with cast metal or
    steel . so , I used the next best thing. But I really hope that the machine
    will perform well . It's already heavy ( 250KG / around 500pounds ) , the
    design is fairly good , and it's stiff ... entire assy is only at mokup level
    now ( very few screws , about 10% of final amount needed ) , nothing
    is aligned yet , and still , the entire **** does not vibrate when I strike
    the column with a rubber hammer ...
    Here are some pics of final project , made in Rhino ... You will see that
    the base structure is pretty solid ...
    Feb 2009
    180
    Quote Originally Posted by katran View Post
    Nice design and work- What's the spindle ? How much do you think your build cost will be for materials?
    Feb 2009
    118
    Quote Originally Posted by jdclark View Post
    Thanks ...
    Spindle is a Colombo RV110 CPE32 ( 10hp , 7,5Kw , 18000rpm )
    Cost ? Probably in the vecinity of 5000USD ...
    Feb 2010
    371
    Holy smokes, your workshop is far too clean. I'm so jealous!
    Feb 2009
    118
    Quote Originally Posted by AiR_GuNNeR View Post
    It was clean ... now is a mess . Here are some pics taken when
    the shop was a little cleaner ...
    Nov 2004
    139
    Very nice machine, and workshop.
    Dec 2011
    colour me green!
    Megesh Govender - South Africa
    Newbie to CNC
    Oct 2011
    218
    Amazing clean workshop do you have cleaners come in? :-)
    Mar 2004
    1306
    Beautiful work. Thnks for sharing, and I am looking forward to seeing the further build pictures.
    Regards,
    Mark
    Apr 2006
    169
    :wee::banana:WOW
    May 2005
    35
    Can't wait to see a video of that mill working.
    Keith.
    Aug 2017
    Re: cnc vertical mill build log ( pics )
    Katran, Today I received a newsletter from CNCZone that highlighted your mill build. I was anxious to see it! When I arrived, I saw comments exclaiming how wonderful it was but as you know, there are no photos, no plans and no video. I surely hope you have back ups that can be shared. PhotoBucket has ****ed us all! Please do not pay the ransom. I think it is the wrong thing to do. It only supports their decision to hold the assets of thousands of people and companies for the purpose of extortion.
    I do hope to see your mill when you get a chance.
    Oct 2015
    7
    machine 3d file:
    https://grabcad.com/library/diy-cnc-mill-1
    hope this help ...
    And Thanks for effort to present this beutiful machine
    Jul 2018
    Is there a possibility that i can get the plans and a parts list for the vertical mill please.
    For the work i do, i think its way to exspensive to buy a new one.
    but i'm new to cnc so i hope you could help me out with this.
    With kind regards
    Sam
    Hi, do you need parts from machine I can supply https://shoptoolusa.com/product/20-p...-tool-changer/
    do you need any questions or support please advise
    David
Page 1 of 6 123
  1. DIY aluminum vertical mill build
    By sergizmo in forum Vertical Mill, Lathe Project Log
    Last Post: 09-07-2015, 04:59 PM
  2. Replies: 0
    Last Post: 01-05-2013, 11:51 PM
  3. Looking to build a simple vertical mill
    By Crudeau in forum Benchtop Machines
    Last Post: 10-27-2012, 01:13 PM
  4. Custom CNC vertical Mill build T-Minus 24:00
    By cncgabe in forum Vertical Mill, Lathe Project Log
    Last Post: 03-31-2012, 02:18 AM
  5. Started build on CNC Mill. Lots of pics, sorry.
    By EvanZ in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2008, 02:24 PM
