586,123 active members*
3,324 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam x5 tool path help
Results 1 to 6 of 6
    Sep 2012
    I am making some brake calipers for a school project, and have drawn up the part in solid works and input it into mastercam. The problem I am having is trying to do a surface tool path, I have done them before using the create surface from solid function, but with this part it won't let me select some of the surfaces. Would anybody be willing to take a look at the part and help point me in the right direction, I can message or email you the step. Or parasolid file.
    Thank you on advance
    Dec 2008
    717
    Go ahead and post it here. I'm sure someone will look at it and point you in the right direction.
    Tim
    Sep 2012
    Thanks for the reply. here is the file, i believe i did it correctly, let me know if not.
    Attached Files Attached Files
    May 2004
    4519
    First, you should seriously consider redesigning your part using standard sizes for fillets. A 0.1989" radius is not standard. Might work great for casting. But to make the machining more efficient, thus more cost effective, change these to standard.
    Sep 2012
    ok i will change the fillets, i hadnt thought of that. Any ideas on the surfacing tool paths?
    Oct 2006
    85
    "activate solid selection"
    "select face"
  1. CAM: Tool path generation for ATC Automatic Tool Changer
    By S.Seveelavanan in forum Uncategorised CAM Discussion
    Last Post: 08-09-2012, 04:45 PM
  2. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  3. MasterCAM .nc file path location help
    By ljagger in forum Post Processors for MC
    Last Post: 10-18-2010, 03:51 PM
  4. need help fast 5 axis tool path in mastercam
    By fasttom in forum G-Code Programing
    Last Post: 12-02-2005, 07:22 AM
  5. Replies: 2
    Last Post: 06-08-2005, 12:58 PM
