How do I do this on a HAAS ST-10 LIVE TOOL Lathe.
I have a part that has a finished outside diameter of (7.925mm)/(.3120in).
I need to drill a hole of (1.98mm)/(.0780in) right thru the middle of the part using the vertical live tooling holders on a HAAS ST-10.
I need to hold the (1.98mm)/(.0780in) hole in (+-.050mm)/(.0020in) on center of the part.
I finish the OD, center drill with a #1 c-dril and then drill with a 2mm drill.
According to the the April 2012 HAAS Lathe Manual, on page 140,141,142.
You have to use the alignment dowl pin and set screws to adjust the parallelism with the X Axis.
I am having a very hard time holding that tolerance, I cant seem to align the live tool on center enough to dill straight.
Can you guys give me tips on X Alignment for radial tools on a haas lathe.
If some one knows a good method please explain in detail.
I really want to be able to do this correctly.
