This is from ADTECH 4 Axis High Grade Milling CNC Controller is wide range of used as big type milling machinery , it has good HMI design, with high speed network data interchange interface.
ADTECH Milling CNC Controller feature:
1.10.4 Inch color LCD display
2. ARM9 Processor and FPGA motion control technique, The Process Spend reached 60m/Min
3. Optocoupler isolation, Strong Anti-interference, stable and reliable Processing
4. Large processing storage Space
5. Support Four Axis Servo Motor Control
6. Simply Operation, can connect handheld box and additional Panel
7. U Disk reading functions and also can simulate to IDE Flash Disk, which can demanding to reading data, editing and processing, even large processing
8. USB Communitarian function, quickly and convenient to data transmit
9. Strong network function, can realized multi-machines connection and real time monitor by computer system; It is adopt International standard G Code, can customize change tools function
10. Supporting Strongly B type macro resolve function, it is convenient to develop the motion control processing for the user.
11. 3D graph functional simulation
12. Random modify the program during processing at any time, improving work efficiency
13. Saving function if power failure, password protect, and screen saver
14. Complete and intuitive reflection system in operation status, help user found question timely and settle of it easily.
more information please visit ADTECH www.machine-controller.com
