586,121 active members*
3,523 visitors online*
    Apr 2010
    260
    VF2 Reboots on own
    We have a 96 Vf2 that just started to reboot itself on its own. This happens when the machine finishes a cycle. I pressed cycle start and it rebooted. It happened a few times. I went in, blew out the cabinet, checked all the connections, seems fine now. Anyone have any idea what could cause this just so I can take some preventive measures
    www.machmachine.com
    Feb 2010
    1184
    Check all of the low voltages you can find; +/- 12vdc, and +/-5vdc. These will be present at the servo drive cards, the processor/vido/mocon stack, and at the power distribution board (near the main contactor switch).
    Check to make sure that, where present, you have good voltages. Try tapping on the power supply to see if the voltage will drop out on you. You can try unplugging and plugging back in all of the low voltage connectors; power off of course. Sometimes the connections can oxidize and the reconnection of the plugs will help establish a good connection again.
    Good luck!
    Also, if you haven't done it in a while, backup all machine files pronto! ie: parameters, settings, offsets, variables, programs; just in case.
    Apr 2010
    260
    Thanks I will do all that. Machine has been running fine all day.
    HFo said it is probably the main processor board that needs replacing and it will be $3000.
    Could that really be the cause of intermittent issues?
    www.machmachine.com
  1. Anilam 1100 control jumps and reboots
    By djshop in forum Bridgeport / Hardinge Mills
    Last Post: 05-25-2011, 04:02 AM
  2. Controller Randomly Reboots Itself
    By Geof in forum Haas Lathes
    Last Post: 02-24-2009, 04:30 AM
  3. Computer Reboots?
    By CNCRob in forum Computers / Desktops / Networking
    Last Post: 09-22-2006, 02:13 AM
  4. Computer reboots when I turn on gecko PS
    By JFettig in forum CNC Machine Related Electronics
    Last Post: 08-29-2006, 02:21 AM
  5. Computer reboots everytime I run Mach 2
    By WarrenW in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2005, 12:53 AM
