I presently have a 2007 IH 12Z manual mill that I am contemplating a CNC conversion for. I fully intend to spec, source and install of the components myself as I have designed and built a sizeable CNC router previously. However, that system employed direct drive steppers for each axis as opposed to the servos I am planning to use for the IH mill.
My question(s) are around the sizing of the servo and power systems. If one uses the typical belt drive reduction in the 3-4:1 ratio range, is there consensus or general rule of thumb as to what size/strength of servo is required for each axis. Two such motors I have run across have the following specs:
1. 850 oz-in, 72 vdc, 8.5 A cont (38 A peak), 4200 RPM
2. 1125 oz-in, 90 vdc, 7.8 A cont (40 A peak), 3200 RPM
Are either of these motors in the ballpark as being suitable for this conversion? Overkill, underkill, etc...? If so, how does one go about determining the appropriate size of power supply to drive all three axis?
Thank in advance for any help.
-Tulsah
