Looking to see what everyone throught would be the best approach to milling a part. The part is 2x2x2 steel. I need to cut out a 2x1x1 out of the side of it, basically making it a L shape.
Being that its steel, does it make more sense to use a larger bit say 1/2in. and just keep surfacing it until I get to the desired depth? Or use a smaller bit say .1875 to cut slots in the steel to meet at the desired points therfore removing a corner chunk of the steel.
I usually work with aluminum and just wondered if there was a recommended method for harder metals?
