Hello
I was just wondering what Gibbscam (2007) has to offer when It comes to Through Spindle coolant. All I see is Flood coolant. Is it just a post upgrade, or is it more than that?
Hello
IF YOU MAKE EITHER A DRILLING OP OR MILLING PROCESS.THEN DOUBLE CLICK ON THE OPERATION # IT WILL OPEN UP AND YOU CAN TYPE IN YOUR THRU SPINDLE COOLANT COMMAND IN THE [AT OP START] WINDOW. FOR MAKINO IT LOOKE LIKE THIS
"M26 G4 X5.(THROUGH SPINDLE COOLANT)" WHEN YOU POST YOUR PROGRAM IT WILL BE IN PROGRAM AFTER TOOL CHANGE. YOU HAVE TO USE QUOATION MARKS.EVERYTHING INSIDE THEM WILL POST
" IF YOU MAKE EITHER A DRILLING OP OR MILLING PROCESS.THEN DOUBLE CLICK ON THE OPERATION # IT WILL OPEN UP AND YOU CAN TYPE IN YOUR THRU SPINDLE COOLANT COMMAND IN THE [AT OP START] WINDOW. "
Thanks for the tip, but it looks like my post is not setup to allow this.
glovebox20
