Hey guys. New here so hi :wave:
In the last couple days I have gotten a huge hair up my * to try and build a mini CNC.
This will actually mostly be used for aluminum and I have some hopes to do some steel but that's not required. It would just be an added bonus.
I have quite a lot of experience in the mechanical design and fabrication side of this from my last job.
I was the primary fabricator for a number of machines that we made for production in the composites industry.
Here is a picture of one of the machines. This one can lay up a unidirectional thermoplastic composite blank up to 2 meters by 2 meters.
I also have several years experience in manual machining and just a little experience with CNCs.
Anyway I got laid off and so I have started out on my own doing metal fab, welding and custom fabrication.
I would love to have a full machine shop but space for me is even more limited than money right now. Once I started thinking about it I decided a little 600x400mm CNC would be able to do a large majority of what I wanted to do. Plus it would be a great first step at getting into this on my own. Like I said I am very familiar with the mechanical side and better versed than many when it comes to the electrical but when it comes to software, programming and tying it all together well I'm still a little :drowning:
Even though I want to do mostly aluminum I decided to post here since this is where most of the DIY and most similar projects seem to be.
I wanted something very rigid and also very compact. For the sake of staying compact I decided to go with more of a gantry style than moving tables. The downside of Gantries though is you have a lot of leverage being applied to certain areas. The legs that go down to the linear ways seemed like a particular weak spot to me and after some time thinking I decided to get rid of them all together.
This design would either use 80 x 160 80/20 or 2" x 6" steel tubing.
I am leaning toward the steel tubing since it would be a little cheaper for me and should be a little more rigid. I'm thinking probably 3/16 wall.
The base would naturally have considerably more reinforcement than the drawing. Possibly 2x2 square tubing welded to the bottom then faced or something similar.
The 2x6 would sit on top of the base with rails on top of it that the gantry would sit on.
I'm not set on one idea for driving this axis. In the model the lower shafts are concepted ballscrews. I wasn't sure if belt drive would be best or if I could put a motor on each one and if that would be best. Or if I could do something like a gear drive on each.
I am open to suggestions on that. I like the idea of two ballscrews because between those and the linear rails it should be quite rigid and resistant to torsional forces in the x,y directions.
One other thought would be to run a second gantry rail across so the z axis was supported on both sides. I don't know if this would be necessary but it would make for one burly little unit and it wouldn't really get in the way much.
So I guess that's pretty much it for the mechanical. I'd love any input I can get.
I am also curious what sized and type motors people would recommend for a setup like this, what kind of controllers should be used and how to tie the whole package together properly. I'm not looking for crazy feed rates or anything.
I am almost completely Linux based and would prefer to run it off linux if possible. From what I have read it seems like there are some decent options out there. I just don't know if I need to pick specific controllers/hardware with that in mind or if it will work with anything.
Of course I want Ferrari performance but more importantly I'm on a pack of ramen budget.
