we finish mild steel disk masters with 1.375" HSS cutter, 6 flutes at 130rpm and 1.5"/min with 0.002" stock removal on final finish cut. Coolant is Valentite VNT700 + water.
Finish and accuracy is very close to that of ground part after you buff it with scotchbrite.
sounds too good to be true!
How long does your cutter last??
With this small of a chip load I would guess that recutting small chips would fracture the edge of the tool make lines appear in the material????
But I have never tried it.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
