586,121 active members*
3,012 visitors online*
    Oct 2012
    Exclamation Decimal point
    when NC output the decimal point show is 9.9563 how i need to change it to 3 decimal point? I am using Esprit 2012
    2932
    Quote Originally Posted by touchdiy View Post
    Open your post.asc file in a text editor. There is a Formatable Codes Section (see attached E2012 Formatable Codes Key.jpg) that formats output for inch, metric and zero.
    For each code is a format line. Change the number in the highlighted column from 4 to 3 (see attached E2012 Formatable Codes Example.jpg).
    Attached Thumbnails Attached Thumbnails E2012 Formatable Codes Example.jpg   E2012 Formatable Codes Key.jpg
    Oct 2012
    thk dcoupar
    Jun 2010
    81
    How did this work out for you? Depending on the machine, sometimes you need 4 place decimals when doing things like engraving ... Sometimes only 3 place will give ARC errors....
  1. Decimal point in a comment?
    By Brakeman Bob in forum Fanuc
    Last Post: 04-09-2019, 08:29 AM
  2. DECIMAL point needed
    By pilot001 in forum Mach Wizards, Macros, & Addons
    Last Post: 01-15-2012, 03:25 PM
  3. Forcing a decimal point from a pci
    By inflateable in forum EdgeCam
    Last Post: 10-28-2008, 02:58 PM
  4. Illegal use of decimal point
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 07-08-2008, 12:06 AM
  5. decimal point
    By stevieboy in forum Mastercam
    Last Post: 01-10-2007, 12:42 PM
