Re: Chris' G0704 build
Originally Posted by
Fastest1
I am having issues too with the ESS/MX3660 combo in regards to accurate spindle speed control.
I do believe part of the problem or misunderstanding is that the ESS varies a 0-5v signal, not 0-10v like the KBMM wants or needs. There is an ability to scale that 0-5v within the KBMM or Mach ( I am not sure of how to do it just yet). Or that is what I understand as the problem.
Page 14 of the Manual for the MX3660 is very clear. The PWM signal from the ESS needs to be on pin 14 of the DB25 that connects to the MX3660.
The MX3660 will produce an isolated analog voltage that is a ratio defined by the PWM signal. A 25% mark/space ratio PWM signal will produce an analog voltage (on the 0-10V terminal) that is 25% of the voltage connected to terminals +10Vsc and EGND. This is shown in section 14.3 on pages 15 - 16 of the manual.
It states that the voltage that can be used can be 5-15Vdc which means that you can use KMBB to power it.
Also note that the maximum voltage that can be produced out of the MX3660 is 1.1V less that the supply fed to it. For a 10V supply from a VFD, you will only get 90% of the top speed out of the spindle, which may be a bit limiting and disappointing in some cases.
Cheers,
Peter
Homann Designs - http://www.homanndesigns.com/store
