586,113 active members*
3,052 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > mitutoyo scale a11-n wires pulled
    Feb 2008
    9
    Hello looking for info for rewiring my scale the wires pulled out
    thank you speed
    part # 935579
    Jun 2007
    3757
    Have a look at one of the other axis, if possible, and copy what you see.
    After soldering, make sure wire is %100 supported so wire does not fatigue at solder flexible wire junction.
    Feb 2008
    9
    Quote Originally Posted by neilw20 View Post
    other scale is different so still looking for info
    thanks speed
  1. mitutoyo linear scale pinout
    By pham1129 in forum Bridgeport / Hardinge Mills
    Last Post: 04-21-2021, 12:31 PM
  2. Mitutoyo AT116 linear scale
    By braco in forum Uncategorised MetalWorking Machines
    Last Post: 12-18-2017, 03:47 PM
  3. Taig Z Axis Being Pulled Down into Aluminum
    By NicHoza in forum Benchtop Machines
    Last Post: 04-02-2011, 12:01 AM
  4. Sargon DRO & Mitutoyo AT715-750 Scale
    By ynnek in forum CNC Machine Related Electronics
    Last Post: 08-02-2009, 04:30 PM
  5. mitutoyo linear scale cable pinout
    By pham1129 in forum Uncategorised MetalWorking Machines
    Last Post: 12-08-2008, 02:25 PM
