586,508 active members*
3,300 visitors online*
Results 1 to 7 of 7
    Oct 2012
    Soft filament types?
    hello all,
    Am looking into creating an object with an outer wall softness/pliability of a PVC rubber ducky.
    Been reading up on makerbot and i'm getting the sense that the filament type
    is more stiffer?
    If a soft filament type exists and if it's durable enough i can see producing it
    to sell initially straight from the printer, if not then i will go with the standard filament for prototyping purposes. thank you in advance! pete
    3D printing of Nylon produces softer parts.
    3D printing gets more flexible with Nylon extrusion -- Engadget
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Jun 2004
    17
    Soft output 3DPrinter
    Fabbster's flexible material for 3D printing
    3D prints of flexible material made on a Fabbster 3D printer. Fabbster uses a special material concept: SDM - stick deposition moulding.
    fabbster - A home 3D Printer prints flexible material
    I don't think it will be available for a while?
    Quote Originally Posted by peteguam View Post
    hello all,
    is more stiffer?
    Jun 2005
    176
    You want melt-processible elastomer. This is used in "overmoulding" operations where a soft rubbery layer is overlayed on hard plastic.
    You may not want to overmould but the material is pretty resilient and flexible so I'd hazard it would be OK on a standalone part.
    If you have an FDM printer I don't know that anyone actually has an MPE filament available.
    Have a look at this: link
    Dec 2012
    6
    Feb 2013
    Smile
    The great thing about flexible filaments is that the thicker you print the object the less flexible the printed part becomes. This is the most flexible filament - it seems more elastic than anything else I can find on the interweb and its in stock Flexible - Rubber-like (1) 1.75mm ABS 500g / 1.1pound
    Are you talking about flexible filaments? Try the Taulman Filament.This material bends on high temperature (from bed temperature of 70°C to an extruder temperature from 210°C-215°C). Very compatible in 3D printers like RepRap, Makerbot, Printrbot, Objet, Formlabs, Buccaneer, ORD, Leapfrog and other similar. Taulman PETT is very tough and semi-transparent and in addition to this, it’s approved by authorities in USA.
  1. CNC filament winder(carbon fibre)
    By wallygator99 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 10:49 PM
  2. Filament Winder Retrofit
    By cgrenke in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2014, 05:16 PM
  3. Filament Winder
    By RotorRouter in forum Open Source Controller Boards
    Last Post: 03-31-2014, 05:14 PM
  4. Soft rubber filament
    By dasflux in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-27-2014, 07:51 AM
  5. I from Russia. Me interest filament winding machines
    By necom in forum Community Club House
    Last Post: 06-07-2012, 05:55 AM
