586,075 active members*
3,984 visitors online*
Page 1 of 3 123
Results 1 to 20 of 52
    Aug 2011
    617
    using my CNC router as a lathe ?
    Hi all
    I have just taken on an order for 50 turned handles-money up front. The idea was, I'd use the money to built the lathe attachment for my existing CNC. Then make
    What I need to know (have forgotten) is what is involved software wise ?
    I'm using EMC/LinuxCNC. Vectric Pycam Inkscape etc. (no mach3)
    I fugure I need to make a new config file to drive the X,Y,Z differently/swap the axis about.
    Anyone here already doing it ?
    Just thought I'd ask, before figuring it out for myself
    Cheers
    Rich
    My 1st Build (ongoing) http://www.cnczone.com/forums/diy-cnc_router_table_machines/134670-one_big_one_smaller_my.html
    Apr 2004
    5737
    Who told you you could use your CNC router as a lathe? Are you talking about putting a piece of wood in the spindle and fixing a tool to the bed? That won't work for a number of reasons.
    Or did you mean that you're adding a rotary table for a 4th axis? That won't make it a lathe, although you can make radially symmetrical parts that way. In that case, the simplest thing to do is to put a clamp on the Y axis so that it won't move, position it at the center of the A axis, lock it down, and transfer its cable to the motor on the rotary table. The new configuration would be XZA.
    Andrew Werby
    www.computersculpture.com
    Aug 2011
    617
    Hi Andrew
    nearly ! instead of the 4th axsis in it's true sense, I was going to mount a head and tail stock to the bed and just spin the work piece - just like a lathe. But have the x control the depth of cut, and y move along the work for end to end. the router/spindle, would be redundant, and I would mount a cutting tool to the Z , perpendicular to the work
    does that make sense ?
    Richard
    Feb 2009
    2143
    Quote Originally Posted by awerby View Post
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Pretty commonly done, actually...
    Just one example:
    http://www.cnczone.com/forums/tormac...cal_lathe.html
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Mar 2011
    525
    It should work fine.
    Here is a video of mine that shows what you want to do but on a mill.
    Mill as Lathe Optimize - YouTube
    Kelly
    www.finescale360.com
    Jan 2007
    1795
    rich
    you can use virtually any cam, wich one can calculate pocketing,,,,
    that filling routin should work..
    or draw manually the the toolpath..
    for wood is not so critical like for metal..
    DCMT11T304
    this is the carbide insert could work for you.... need toolholder yet..
    type in google and choose one which has undercut..
    pending on the rigidity of your router you can quickly turn one part..
    going forth n back with a ballend mill definetely slower..
    Aug 2011
    617
    Quote Originally Posted by victorofga View Post
    rich
    That's the sort of info I was after ! Pocketing ... hadn't thought of that
    Hardware is easy for me,
    software too ... but need a starting point !
    Rich
    Jan 2008
    853
    I don't understand the reference to pocketing, but no matter. To generate the toolpaths you could layout a profile of a line in the XY plane with any CAD/CAM program, then plug the Z stepper into the Y port and it becomes an XZ machine. Just watch that you have changed the scaling and acceleration values.
    Locking the Y axis is important, obviously. Shorting out the pairs of stepper leads makes the motor into a pretty good brake.
    Cheers!
    Aug 2011
    617
    Quote Originally Posted by PaulRowntree View Post
    Cheers!
    my understanding of the pocketing, was it would work outwards cutting a slice at a time towards the workpiece in the lathe . it made sense to me
    You can't just jump all the way in full depth on the lath, just the same as most other things. Just like roughing , then finishing in trad cnc
    rather than swapping plugs (mine are hard wired anyway) I was going to make a 'lathe' config file for the EMC/LinuxCNC, and just tell it different pins are used for each motor., but the pocketing works without changing anything.
    I'll have a play, and see what I come up with
    yes ... I'll post pics :cheers:
    Apr 2004
    5737
    The Original Poster was talking about using his router as a lathe, not a mill. The spindle on a mill can be run slow enough so that this can work (to a degree) but you wouldn't want to try putting your workpiece in the spindle of a router and spinning it at 20,000 RPM or so.
    Andrew Werby
    Jan 2008
    853
    Ok, I get the pocketing. I was thinking that roughing could be done just by replicating the chosen XY vector a few times, and then progressively flattening them keeping the same reference position for the Y=0 of the material. The attached CorelDraw image shows the effect, with the bottom curve being the final desired shape. Run each as an XZ profile (mind the order!) for a progressive approach to the final shape.
    Cheers!
    Jan 2007
    1795
    at paul
    you need more advertising for your warpdriver.. thats some great invention
    in my approach, no changing on axises...
    the z movement migth set 0.1 mm depth and rapid plane migth lift over the largest diameter..
    my concern was the tool is fixed onto Z axis, and using the pocketing fill routin, the tool moving along the rotating axis, forth n back while approach toward the center..
    step over set in the pocketing, that will define the depth of pass
    i made my setup as exported toolpath to dxf, import back and some node editing ... and go
    edit
    ok... i just read back... well for miniature parts the sndle also could work... i dont want to try that version... i have a small 7x10 metal lathe too so for metall i would try.. but i dont think it would work really... for metal need more rigidity than my routergantry has..
    for wood its worked..
    i think it afford when series coming up..i made some setup... next time i make pictures..
    i using the harborfreigth wood lathe..
    it was about 270 a 12x33 inch cast iron lathe..
    Jan 2008
    853
    at paul
    I am glad that you like it! It isn't as good as Aspire, but it does add some tricks to VCP or any other 2.5D gcode output.
    Cheers!
    Paul Rowntree
    WarpDriver, SkewCalc available at PaulRowntree.weebly.com
    Aug 2011
    617
    I'm wondering now if I could use a router bit as usual, and just approach the work side on ?
    Jan 2008
    853
    Quote Originally Posted by TrickyCNC View Post
    I was just wondering the same thing! The nice thing about using the Z motion of the CNC to cut towards the centre of the spinning stock is that the step-over (step down?) is set by the cutter tool etc, but it could be relatively large. If you use the edge of the cutter, cutting the material from the side, then the step-over has to be less than half the tool width.
    I would stick to Z motion cutting the variable diameter of the piece.
    Either way, you have to be prepared for some very high relative velocities between the tool and the work. Even a lowly 700 rpm turning speed can translate into thousands if inches per minute. Better buy strong bits (and several of them!).
    Paul Rowntree
    Vectric Gadgets, WarpDriver, StandingWave and Topo available at PaulRowntree.weebly.com
    Feb 2009
    1290
    I remember a build thread here on the zone that had the Y-axis (gantry) extend way over the table on one side. IIRC on the over-hang side he mounter a wood lathe, I can't remember it completely it was some time ago but the idea was to use the lathe as a rotary axis without the controller, with the X-axis moving the length of the lathe and the Z holding the tool.
    Like I said it was a long time ago, I might have it wrong.
    Thank You.
    Aug 2011
    617
    Quote Originally Posted by Drools View Post
    I've seen it done in several similar but different ways.
    I've seen a router mounted on the end of a gantry.
    Khalid (sp) had a setup he just bolted to the bed.
    I designed over the end of bed cutting into mine,, so I have the option to permanently mount something 'off the edge' too. Although I think for these small turnings, I might go with bolting something to the bed.
    Paul - the Z cutting will still have a lot of sideways action going on, from the work turning. I might set the Z with the bit on the horizontal center of the work, have the work turning so it is meeting the bit on the up stroke, and carefully cut side on for now. up down Z cutting will be limited by Z travel and work size, until I can get a setup off the edge, and when I do that, I'll go with a proper 4th axis.
    I'll get something fudged together over the weekend. I just got stuck on an easy way to control it. I think the pocketing is just such a simple idea. Each pass will be sett by what you tell the cam program the size of the bit is.
    Mar 2011
    525
    Andrew Werby
    Good Point! LOL
    Kelly
    Jan 2007
    1795
    paul
    in the name of hobbyist, thank you to put in your avatr both program..
    well, its true they cant replace a program like aspire that developed since 20 years ago..
    but hobbyist as they hardly got trogh to building a machine, they will praise your name for this.. they migth dont have to buy program on first day for thoushands
    nah... for you ... i made some cut with my lathe... i know you interesting on it..
    paul
    made photos you, to seeing how i placed cutters..
    my concern is simple...
    for these sharp inner edges, need 1/16 bit, diameter 42 mm means ~120mm perimeter... means about 800 pass forth n back counting with 300 ipm... in luckily case you migth get the finish pass about 3 pass...
    on the diagonal was about 60 mm and deepest point is about 30 mm dia so at least two pass
    means 800x14inch multiplied by 2
    means 22400 ich cutting length divided 300 ipm says approx 74 min
    to turning it, i made 5 roughing pass with 850 mm per min, and one pass finish 450 mm per min.. about 7 min...
    thats a difference..
    by the way, it worth only for series.. invidual pieces, 2-4 pieces i cut by hand..
    as you can see tools are set behind lathe, and facing downward.. so after cnc finish, i can make some cuts with handtools(chisels) or just simply sanding off..
    the post has two tool.. i think can be set 4 and each tool lowered to workposition for proper toolpaths..
    i dont have description about toolpath generating, but used the pocketing fill routin..
    also can be drawn easyly with draftsigth, a free cadprogram..
    dxf can be sent to mach3 and mach converts to toolpath.
    cutters are harborfreigth stuff..
    very wellworth, because the 5 tip already worth more than 25...
    5 Piece Indexable Carbide Tool Set
    theres larger tool also available..
    i tried to show this method long time ago for other users... however their ""professional""" advisors told them it is not possible with router, and with vectirc programs..
    vectric programs are not supporting lathework... this was several times question, and vectric expressed it..
    paul, if you interesting more, i can send you in email more pic...
    best regard
    viktor
    Aug 2011
    617
    Hi Viktor
    that set up look about exactly what I had in mind. Good to see it works
    Thanks for posting
    Richard
Page 1 of 3 123
  1. Router Lathe Combo ?
    By hotbike in forum DIY CNC Router Table Machines
    Last Post: 09-02-2013, 09:39 PM
  2. Lathe Spindle for CNC Router
    By tpsimer in forum CNC Machine Related Electronics
    Last Post: 02-06-2011, 05:53 AM
  3. Router or Lathe
    By Dman65 in forum Wood Lathes / Mills
    Last Post: 07-30-2009, 02:06 PM
  4. A Small Lathe Router
    By Clockwork in forum Open Source CNC Machine Designs
    Last Post: 12-27-2007, 04:46 PM
  5. CNC Router Lathe
    By wjfiles in forum DIY CNC Router Table Machines
    Last Post: 10-03-2006, 12:34 PM
