Hello I am using a 3 axis cnc that was build by someone else, And I am hoping to add a lathe and tangential cutter, for cutting glass. My plan is to install a second parallel port and connect another breakout board.
I am currently using a c11 board from cnc4pc.com with 4 steppers and gecko drivers.
I would like to stay with the same hardware as much as possible to simply things. Which board would you recommend?
Also any general advice would be appreciated, Especially any cut files for the wood tail stock, chuck setup that I cant seem to find.
