Originally Posted by
AiR_GuNNeR
The 150watt rating is simply the power that the supply is capable of supplying. The 80 watt rating of the tube is the power that the tube will consume. Having the larger power supply is actually good as it does not load down the supply as much.
AiR_GuNNeR you better shut up than talk such stupidity.
Every laser "tube" and every laser PSU has its own triggering volltage, trigerring current, work voltage and current.
If you use 150W PSU for 80W "tube" you will shorten "tubes" life extremely.
You can use 100W PSU for 80W "tube" but not 150W PSU.
CNC lasers, constructions, service
