Greetings
I am looking at purchasing a machine, and Hurco is one that is being considered.
What are your thoughts and recommendations.
Thanks for all your input
Greetings
I am not sure what type of machine you are looking at but I will tell you about our machines. We have 3 VM2's which I think they now call them VM20, a VMX42 (milling machines), a TM8 and a TMM10 (lathes). I think the thing that makes the Hurco's stand out is their conversional programming. We do about 99% of our programming on the machine and the rest we do with Pro Manfacturing. These machines run 10-11 hours a day and we have ver few problems. I don't think we have more or less problems than what you would get with any other machine company. The 3D conversional programming is second to none and you can do a ton of stuff with it so you don't have to go to an offline package. Let me know is you have an specific questions and I will see if I can answer them. Also we have had the mills and the TM8 lathe for 7 years and the TMM10 for about 3 years, if you were looking for service life.
Bernie
Hurco has one of the easiest conversational programing capabilities out there. Easy to pick up and learn quickly. I have delt with Bridgeport, Haas, Fanuc, and Fagor controls. Hurco on conversational is start running the day you get it.
Jetski (alias Tooling and Engineering Czar)
"I may not have the keys to success.. but I have learned to pick the locks"
