587,224 active members*
3,079 visitors online*
    Apr 2005
    345
    What pull studs
    I have a BT40 VMC15....actually not sure what pull studs it uses. I have short stubby 45 degree studs.
    I am trying to determine if this part number will work, I see them fairly reasonable on an auction site......they "look" right , but are the other options visibly different besides the length?
    PS BT40 - 45 DEG M16 ANSI B P/N 7300018 4517018
    http://www.scpconcepts.com
    May 2004
    4519
    Most new machines have a label on the machine indicating the correct pull studs for the spindle. Lacking this, check the machine manuals.
  1. Haas Pull Studs
    By rrbmachining in forum Haas Mills
    Last Post: 08-12-2013, 01:22 PM
  2. Pull Studs - M16-20 - Fadal - CAT40
    By smokediver576 in forum Uncategorised MetalWorking Machines
    Last Post: 10-26-2010, 12:41 PM
  3. Pull studs – use thread locker?
    By helocat in forum Haas Mills
    Last Post: 06-09-2010, 05:17 AM
  4. Stama MC326 Pull Studs?
    By awilliams684 in forum Uncategorised MetalWorking Machines
    Last Post: 03-16-2010, 03:03 PM
  5. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
