586,075 active members*
3,976 visitors online*
Results 1 to 14 of 14
    Mar 2010
    621
    Leveling feet?
    Just curious what everyone is using for leveling feet since most concrete floors are horribly unlevel...?
    Adam,
    Apr 2006
    3206
    I like Barrymount
    You can cheat and make your own out of sandwiched steel plates and hard rubber sheet... with a leveling nut/bolt. Works just fine.
    I make my own with hockey pucks and carriage bolts. They work very well.
    Feb 2009
    6028
    Awesome, another use for hockey pucks ! I have one in my steering shaft on my Porsche, since replacements are too soft.
    Aug 2012
    621
    Harmonic dampers, and now leveling feet.. I'm starting to envy those who live far enough north for hockey pucks to be a common item.
    Luke
    Mar 2010
    621
    Nice! So do you drill the bottom of the puck for the head of the bolt to recess a little or just tighten it up and let it go?
    Adam,
    Jul 2007
    675
    Quote Originally Posted by adam_m View Post
    Adam,
    I hear you. My shop is on a hill so everyting is on a 10 degree incline. I use these: Best Casters Period. I used them on my workbenches initially, then put them on every machine in my shop. Result: everything is mobile and can be level in a moments notice. I've changed shop configs 3 times in the last 2 years. Everything I have will ride on these from now on.
    My 0.02
    Jan 2012
    394
    That is awesome Gerry!
    I was looking at some of the big ones sold by McMasterCarr at a whopping 40 bucks apiece.
    Your Idea seems much much cheaper.
    Yep, $2 each.
    Drill a counterbore about 3/16"-1/4" deep, as the bolt head will pull into the rubber a little bit.
    It's not my idea. The original owner of Industrial Hobbies used to have a bunch of tips on his website, and this was one of them.
    Mar 2010
    621
    Great posts... got to love the high cost of the Hockey Puck, lol!!
    MRM RCModels, how do those things level, do they unscrew or something?
    Jul 2007
    675
    Precisely, there is an orange wheel on the inside that extends a rubber foot from inside the caster. Turn the wheel the other direction and the rubber foot retracts. Best of both worlds.
    Oct 2010
    317
    I used these on my plasma table, they are only $5.77 each for the 2" square and they support 660lbs each. They also sell them for round tubing.
    McMaster-Carr
    Aug 2004
    54
    LEEVALLEY.COM sells hockey pucks made in europe for $1.00 @ piece or $.90 at +10 .
    they also sell high friction covers , so you can make your own bench pucks . the part number for the pucks is 88K59.02 .
    SINCERELY ,
    EIGSTEIN
    Nov 2012
    Found a good deal
    Found a great deal on some heavy duty leveling feet on ebay from seller montcorealty.
    1/2" HEAVY DUTY LEVELER FOOT/FEET with NUT PLATE, QTY12
    1 2" Heavy Duty Leveler Foot Feet with Nut Plate QTY12 | eBay
  1. Box Wrench for Leveling Feet
    By Donkey Hotey in forum Haas Mills
    Last Post: 08-07-2023, 08:05 AM
  2. Getting my feet wet
    By M250cnc in forum LinuxCNC (formerly EMC2)
    Last Post: 07-07-2010, 09:18 AM
  3. Looking to get feet wet
    By xlatin in forum Benchtop Machines
    Last Post: 02-15-2010, 07:17 AM
  4. Just getting my feet wet
    By Dabeechman in forum DIY CNC Router Table Machines
    Last Post: 10-05-2008, 12:55 PM
  5. swivel leveling feet
    By DanOSB in forum Mechanical Calculations/Engineering Design
    Last Post: 09-20-2005, 02:37 PM
