Hello, all;
In the ongoing saga of repairing/replacing parts and electronics on my Lagunmatic 250 CNC, I've discovered that the ball screws have some backlash - when I turn them they rotate without load for a little bit.
I verified this with a dial test indicator to make sure it wasn't a movement too small to see, and it's not. I can rotate the timing pulley that is directly attached to the ball screw in both cases by about 1.5 - 2 notches before the table starts to move. I can wiggle it back and forth that much without moving anything.
The pulleys on the ballscrews have 50 notches total. If I'm doing the math right, that means my ballscrews don't engage when reversing direction for 14 degrees of rotation. My ballscrews are metric 5 lead, so they move 5mm per turn, so that is about .2mm of linear movement backlash (8 thou), which seems like an awful lot.
I know some CNC controllers compensate for backlash when reversing in software, but I don't know if this is a normal amount or not.
Once engaged and moving the table, obviously the ballscrews move every time they are turned even a little.
Anyone know if this is a normal amount of backlash, or if not what could be going on? Worn ball nuts, worn screw, or was it just designed this way?
With this much backlash, how would it be possible to eg. interpolate a circle, with all those direction reverses?
Erik
