586,096 active members*
3,732 visitors online*
    Jan 2012
    9
    Delta interver problem
    dear all
    i need help please
    for my china maxicam machine " maxi -s -1530 servo motor spindle 4.5Kw with DSP hand
    x,y and z moved well the spindle doesn't work "turn "
    nothing show on the screen of the delta interver
    Did you check if wire connected very well between spindle and Delta inverter?
    Amanda Cheung from OMNI, www.omni-cnc.com,
    [email protected], Skype: omni-cnc
    Dec 2010
    33
    check power to the inverter, there is an overload in the panel, reset this.
    Ex Emach Service Engineer, contact me for assistance.
    Jan 2012
    9
    hi my freinds thank you for your help the problem it was in the wire connection but please now i have problem my spindle it doesn't turn correctly the problem in the parametre seting P00 AND P01 AND P07 FOR THE SERVO MOTER HD 4.5 KW
  1. Need Help! Delta servo motor problem
    By luckydoglele in forum DNC Problems and Solutions
    Last Post: 02-01-2012, 02:58 PM
  2. Lagunamatic 310 Delta 10 Z axis problem.
    By dsbrain in forum Uncategorised MetalWorking Machines
    Last Post: 05-27-2011, 03:50 PM
  3. Problem with Delta Tau PMAC2-PC ISA
    By =aike= in forum Servo Motors / Drives
    Last Post: 11-17-2010, 08:42 PM
  4. problem finish loading program to delta 20
    By dingo0722 in forum Uncategorised MetalWorking Machines
    Last Post: 06-09-2010, 01:47 AM
  5. Problem with wiring limit switches to Delta Tau Pmac
    By jatchan in forum Servo Motors / Drives
    Last Post: 02-09-2009, 02:41 PM
