586,060 active members*
4,192 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Dec 2004
    26
    086 Alarm on Fanuc OM
    I am new to CNC and bought a Mill with a Fanuc OM control. When trying to upload DNC, I press the input key and LSK flashes momentarily and an 086 alarm appears on the monitor. I believe the problem has to do with parameters, as this occurs before the upload starts and even occurs when the comms cable isn't connected. Any help would be appreciated. Thanks
    24221
    The Data ready signal is detected as off. I would make sure you have the 3 wire 2,3, and 7 for a 25 pin D. communication cable, with the handshake jumpered out 4-5 & 6-8-20.
    If the cable is disconnected it probabally will fault for sure.
    See Cadem.com for the cable connections and parameters.
    Al.
    Albert E.
    Dec 2004
    26
    Hello Al,
    Thanks for this. Is it possible that some DNC packages require a non-standard pin-out config. The reason I ask is that I bought the comms cable from a Fanuc specialist and they tell me it is guaranteed to work with an OM control (except it does not with Alphacam DNC). Thank you.
    Darryl
    24221
    Fanuc generally show two types of cables, handshake connected and H.S. jumpered out as I mentioned.
    Check to see what type of cable they sold you. If you cannot make the cable up yourself, tell them you want a three wire cable with the Hand shake jumpered out both ends.
    And confirm that AlphaCam can be set for software handshake.
    Al.
    Albert E.
    36
    I've had a lot of problems with the older OM and 6T controls... and only half of our machines will upload. They download fine but get the 086 alarm on upload... Our millwrights believe this is a problem on the board an the company would rather us enter a 5 page program by hand then replace the board (running high volumes).
    Try write a program on the controler and then send it to the PC. If you can punch and not read, I don't think it's the cable. It could be one of the boards in the controller or, maybe someone knows of a parameter that would cause this?
    24221
    Quote Originally Posted by Heavy D
    Not neccessarily true as the DR signal is a separate line for each direction, if the PC is not looking for it, often uploads to PC work where the problem shows up on downloads to the CNC.
    This is why it is best to have handshake jumpered out.
    Al.
    Albert E.
    36
    Well then he should try it with a cable with handshake jumpered out. The reason I say this is because I make my own cables and they are the same pinout, jumpers that you mention. But like I said, some 0M, 6T controls in our shop will punch a program no problem but get the DR signal alarm when you try to read a program. My problems with these controls have not been with the cable as I've tested the cable for continuity and verified pinouts.
    Dec 2004
    26
    Cable OK
    I got a little further than before and managed to type INPUT without the 086 alarm activating. However, I left a 6k prog uploading for an hour (LSK flashing all the time) but felt convinced nothing was actually happening. I switched off the machine after a while and when I switched it back on got the following errors:
    101; 416; 426 and 436.
    To fix 101, I consulted the manual and tried to set PWE to 1 to carry out a memory clear procedure, but the control will not respond to editing of this param.
    I would really appreciate any help regarding any of the errors. Thanks
    Dec 2005
    4
    One thing you might want to check, fairly simple and easily overlooked. The individual pins on the connectors can become disembobulated and not make a connection or an intermittent connection. I've seen it more often on the female side(go figure). Check to see that you are making good connection, sometimes over time and lots of use the male pins on the cable will push their individual female counter parts in a bit or stretch them out...usually resulting in some head scratching, cursing and cigarette smoking. You may have already checked that but I thought I'd throw it in the mix .
    Jan 2006
    61
    Do you have data protect key turned off? Must be in edit mode with key actuated
    to upload. Don't need it to download. Also when you download make sure you set p389.2, 10.4 to 0 to allow download of 8000 and 9000 programs. Hold eob key simultaneously with output start while starting download of cnc parameters to get option paras. Other paras you need to set are: paras 2.0 to 1, 38.6 & 38.7 to 1,
    552 to 10 for 4800 baud (best especially for 0 control to avoid buffer overrun on
    upload). When downloading part programs type 0-9999 to get all prgrms. Hope this
    helps.
    Dec 2004
    26
    Thanks 'Spark-el' for the very useful param settings. It makes total sense to me that the params are causing the upload difficulties. Right now however, I have no control of the machine due to the 101 alarm. The manual states you should edit setting data PWE to 1 and then press delete while switching on to clear the memory. The problem is I know what to do but while the alarm is functioning I cannot edit this setting. Any workarounds to get control of the machine back would be very welcome. In addition to alarm 101, I have 416, 426 and 436. It may not be necessarily 101 that is stopping me edit setting data PWE.
    BTW, I don't believe the upload got far enough to be the problem mentioned by 'Tolk', but it is useful to know. I will make sure the connectors make good contact to minimise a comms outage.
    Best,
    Darryl
    Jan 2006
    61
    On your memory clear operation, are you turning control off
    then holding delete button on power-up? This should delete
    all part programs and clear the fault. The other faults are all
    apc battery low. Make sure you leave main power on when
    replacing batteries, or you will have to re-reference all axes.
    After clearing all faults you should be able to upload.
    Good luck, el
    Aug 2004
    36
    Question DNC to Fanuc
    Hey Guys,
    I just bought a Makino mill w/ fanuc OM control and am also having trouble downloading from a PC. I wired the cable 2,3,7 w/ 6-8-20 and 4-5 jumpered.
    tried write protect key both ways, changed the parameters as informed to by Cadem.com. Program shows download successful on PC, but when I hit input,
    the LSK light just keeps flashing. Should I try rewiring to full handshake?
    Would it matter? I am wide open for suggestions as I don't know what else to try.
    John
    2932
    It sounds from your description that you send from the PC then READ at the CNC? If so, your DNC software must be configured to wait for the XON or DC code. Otherwise, hit READ at the CNC first, then SEND from the PC.
    Have you tried to PUNCH out a program from the CNC to the PC?
    Is your cable 9-25 or 25-25? If it's 9-25, 2 and 3 are wired straight through. If it's 25-25, 2 and 3 are crossed.
    I wouldn't bother with hardware handshake.
    Apr 2004
    61
    I am sending from the PC to the control, but when the pc looks like have finish sending the Fanuc 0M continues flashing INPUT after awhile I disconnect the cable from the machine an alarm comes on but the program have been tranfered to the machine. Could be this caused by the cable?
    Aug 2008
    151
    86 alarm
    Does your file contain a % sign? That is what the CNC is waiting for to terminate the transfer.
    Warren
    www.uptimecorp.com
    Nov 2006
    418
    Heavy,
    I had the recieve at machine/no send from machine problem on a Mori with a 10M for a long time that I just lived with until I lost the parameters and had to go the long road to get the machine back online.
    Turned out the only problem with sending files out of the machine was that the baud rate was set too high. Set it lower and now all is fine! (Still kicking my own a** on that one). This may not be the issue in others case, but the problem can be the least expected item - pays to experiment.
    Rgds, John B
    Dec 2004
    26
    LSK KEEPS FLASHING
    I GET THIS IF I FORGET TO SET "DNC" TO "OFF" ON THE OM OPS MENU. IF SET TO "ON" I THINK THE MACHINE ASSUMES YOU ARE DOWNLOADING (SAY, PARAMETERS) FROM THE CONTROL TO A PC, RATHER THAN UPLOADING.
    Mar 2006
    158
    I have seen some older Fanuc controls throw up when trying to upload at the same baud rate as the download. Try slowing it down to 1200 and see if you get the same results.
    Aug 2008
    406
    I had a cable coming out of 5m that my sr232 cable pluged into ...The m5 connector was wired wrong.....and causing the 086 alarm...if I had only checked it first it would have saved everyone alot of time....I learned a valuable lesson just because it was allways there dose not mean it is right and check all cables from motherboard to computer....not just the one you make.
Page 1 of 2 12
