Hi guys, im planning to build a machine using Steel Frames, i think that the Y/Z will be too heavy so i want to move the table piece instead the Y.
i finished some drawings, think that if use 200mm support will be rigid enough.
What do you think about this two images? will be OK to place the Y/Z at center or will be better to place it like in the img 2?
diameter of rails will be 20mm rigid and as i told you will use 2 x 100mm support together under the table.
of course design will need to be changed if use img2 instead img1
Thanks in advance,
