alright,
having a little bit of trouble hope you guys can help.
Im trying to hand tap a 1/4-28 .5" deep blind hole into heat treated 17-4 SS (Cert says it was heat treated to condition H900)
i am using a TiCN Coated HSS plug tap with tap magic extra thick tapping fluid.
I have 12 parts to do with 3 holes each. so far i've done 1 part and the tap barely got through the last hole.
so my question is should i be using a different tap material Cobalt? Carbide?
Should i increase the hole size? (there will not be much strain put on the treads). any help would be appreciated.
thanks
Ryan
