586,103 active members*
3,859 visitors online*
    Oct 2012
    Exclamation Machine won't cutter compensate :(
    hi all trying to do a job at work but i cant for the life of me get the vmc to compensate for the cutter and i have it in the format g01 g42 x0 y 25.4 d2 f50 but it still wont work the cutter radious in the offsets is 6.63mm and its position before that line (g01 g42 x0 y 25.4 d2 f50) is x-10 y -50. any help would be great as i really need it. also if anyone knows a quick prog to put a 25.4 mm radius on some 2 inch flat bar would be great too cheers jack
    Also the machine is a Bridgeport vmc 610 xp2 with a fanuc 18i mb
    Aug 2010
    156
    i see the position befor and the G42 line but what is the nex move ??? direction matters
    Oct 2012
    After the compensation is on I'm moving the x axis to do a radius
    Aug 2010
    156
    i need to see more to help you moving the X where?
    Oct 2012
    Thanks for quick replys I solved it all now by instead of moving both x and y at same time whilst trying to comp on I just moved y in to -25.4 then on another line moved x from -10 to 0 cheers
  1. How to compensate for profiler tool
    By George777 in forum Mastercam
    Last Post: 03-21-2012, 03:17 AM
  2. tangential knife corners to compensate
    By josuesitan in forum Mastercam
    Last Post: 02-24-2012, 05:13 PM
  3. Compensate for skew axis
    By aka9950202 in forum LinuxCNC (formerly EMC2)
    Last Post: 07-04-2011, 06:38 PM
  4. Compensate Z flatness
    By rdpdo in forum Mach Software (ArtSoft software)
    Last Post: 03-28-2010, 07:30 PM
  5. Use knee to compensate for tool length changes
    By Korellibopper in forum Mach Mill
    Last Post: 12-07-2009, 05:29 AM
