Does anyone have part numbers or referal to the parts i need to set my OKK fanuc 10m up for a 4th axis, It does not have the interface card, but has been setup in the past.
with macro option you can use almost any index system that has its own controler. like a hass or a tsudakoma. do you know if that is how it was connected befor ? if it was this is not a true 4th meaning you can not contour only position. a true 4th would require a servo drive/amplifier and the table would have to have a Fanuc motor in it.
Im not sure which control it was setup for. I would like to start with true 4th contouring. I do see a table on auction setup for a fanuc0m , but im not sure it would work for my 10m ?
