We have a problem with a Kitamura VMC with i80 control, it is simple but we are having a hard time to do this. The problem is that the spindle motor was dismounted and the control initialized, the control works fine but the spindle orientation is not in the correct position, we have tried to adjust that using parameters from the manual but there is no change, we changed par. No. 1414 in the control but there were no change at all, we also changed parameter C3-1 in the spindle drive, but it just moves a little.
Do you have any advice for this? We want to move the position of the spindle encoder, but before I wanted to ask for your opinion.
Thank you in advance for your help.
Greg.
