586,375 active members*
3,514 visitors online*
Results 1 to 17 of 17
    Aug 2012
    Mach 3 pulling hair out :( help
    so i finish converting my x2 mini mill and want to do a sample cut. i created a simple carving drawing on Deskcnc and then created a g-code, but when i open the file in mach 3, the dimensions change on my X, and Y display. i have tried other image to g-code converters and i get the same results on mach 3.
    i attached the picture i want to cut, and a mach 3 print screen of what i see, and the g-code file. any information would be great. please change the file extension on "this one.dwg" to "this one.ncd" i dont know what im doing wrong
    x should be about +6", and Y +1.5"
    Attached Files Attached Files
    That's what I see when I open it here.
    Go to the MDI screen and see what the limits DRO's show.
    Also, are your default units set to mm's?
    Aug 2012
    here is a screen shot. this is my desktop, but i use my laptop. i get the same looking picture on both. i dont get why the X, and Y are different on the mach 3 screen. the drawing in mach 3 shows it being placed vertically, and not horizontal. my units are in inches.
    here is another pic of when i created the drawing in deskcnc please see
    ah.jpg, limits.jpg and nooo.jpg to see the print screens
    Jan 2007
    1795
    migthbe motorsettings help
    i checked in gcode editor and that shows horizontally...
    thinking loud what is the settings for cordinatasystem... i know mach3 can rotatate
    Sorry, I meant to say the Toolpath screen. On that screen, what do the Program Limits show?
    It display correctly here, and I have no idea how it could display rotated like that.
    Aug 2012
    Vic they are the same as the ones showed in your picture, ger, i included the file bellow for the limits in the tool path.
    have you guys tired loading the file in your mach 3? can i see your mach 3 xml config file? i used the one provided by geck g540.
    right now i am just useing the mach 3 software but i am not connected to my gecko driver or smooth stepper. i just want to see if i can get mach 3 to display the project i made horizontal on my x if that makes sense
    or maybe you guys can include a file your created to see if it displays correctly on my screen. this is frustrating i just spent like 2 hours figuring out a smooth stepper driver error, and now this.
    Jan 2007
    1795
    look at for lower left corner...
    check if it were zero
    edit... your pinout probably ok... sorry for misleading before..
    Jan 2007
    1795
    what i guessing, if you have preset xml....
    just guessing...
    many manufaturer use the gantry as x and long axis as Y so migthbe thats why the local system rotated
    edit i think gerry knows it... however in normal situation we always orientate part in the program we make toolpathing..
    so virtually not a lot reason to use it...
    Aug 2012
    Vic, im a alittle confused, would i need to change some settings in my mach 3 or in the program i create drawings?
    Jan 2007
    1795
    look at for the picture i posted... mdi screen
    in the lower left corner you can see local system rotated
    that must be zero value
    yours probably shows 90 deg
    please, click on the picture i posted... zoom in..
    Aug 2012
    mine shows zero as well, but when i enter 90 then it shows it the correct way... hmm
    Jan 2007
    1795
    tomorrow try to call brian barker... or send him email..
    artsoft a very helpful company...
    Jan 2007
    1795
    have you run or load priorly other program?
    i mean g-code?
    this you posted, shows a G80 .. im not sure about that command..
    virtually that command comes after G81...
    so best idea asking artsoft..
    Aug 2012
    ok thanks for your help. i used image to g-code, and desk cnc. for some reason it doesnt look like its capturing the full drawing info or g-code. what program do you use?
    I know what it is. You're in demo mode, and Mach3 is only displaying 500 lines of code. So your only seeing 1/4" of the 6" length. If you had a Mach3 license, you'd see the entire thing.
    Aug 2012
    geeeeeeeez thanks Gerry i would have never known.
    Jan 2007
    1795
    i knew gerry has answer :-)
    i didnt thinking on that..
    you can split your code up to prts..... but simpler to wait to get working mach3..
    i used about 2 or 3 years and works great
    now im using ncstudio, that came with router..
    after the small i started to build, get ready i going to use again mach..
  1. Home switch setup (pulling my hair out)
    By Dahlberg in forum DIY CNC Router Table Machines
    Last Post: 04-20-2012, 06:09 PM
  2. FLA-200 Linear Bearings Pulling my hair out!
    By crash5050 in forum Open Source CNC Machine Designs
    Last Post: 05-07-2011, 05:31 AM
  3. Pulling hair out! Problem with material webbing.
    By xncrman in forum Vacuum forming, Thermoforming etc
    Last Post: 01-29-2011, 04:58 PM
  4. pulling hair out
    By radioman in forum DIY CNC Router Table Machines
    Last Post: 01-05-2010, 10:16 PM
  5. 203V Pulling my hair out!!
    By WilliamD in forum Gecko Drives
    Last Post: 04-18-2008, 07:09 AM
