586,115 active members*
3,493 visitors online*
    Mar 2012
    Need rs232 input file to osai ab 8600.
    Need rs232 communication input file to osai ab 8600.
    I have a cnc center from cms equipped with osai AB 8600, my old mastermill cam and postprocessor died with an old pc, and i'm not able to find win 95 compadable hardware. :-)
    I’m trying to adapt new software to communicate with the osai,
    I need a printout, or a copy of a serial rs232 file sent from a postprocessor to the osai in order to find the communication speed, handshake and codes to tell the osai to recieve and what memory bank to save the program in etc. before and after the g-codes to set up my new cnccam.net postprocessor. Could anyone please help me with that?
    Sep 2010
    6
    PARAMETERS FOR THE AB8600
    INFO FROM MY LEGACY NOTES, CONTACT ME AT Highland DNC, LLC. IF YOU LIKE.
    CABLE
    HUB CONTROL
    2 2
    3 3
    7 7
    4 TO 6 TO 8 TO 20
    SHOPLINK HUB PARAMETERS
    CNC PROTOCALS
    DOWN B=ALLEN BRADLEY
    UP A=BASIC PROTOCAL
    PARITY
    DOWN A= ASCII EVEN PARITY
    UP A= ASCII EVEN PARITY
    BAUD 9600
    STOP BITS 2
    LEADER TRAILER SENT TO CNC N
    ASCII NULLS SENT TO CNC N
    COMMENTS STRIPPED N
    CONTROL PARAMETERS
    8600 SYSTEM CPU MODULE (80286) JUMPER SETTINGS
    P8 2-3 DISABLE DATA TERMINAL READY
    P9 2-3 DISABLE REQUEST TO SEND
    P13 1-2 RS232 ACTIVE
    Dec 2008
    Word of warning AB8600 has live voltages on the port pins do not short unused pins to ground or other pins live voltages are used to drive paper tape punch...
  1. Osai 8600
    By PaulWCNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-11-2019, 06:52 AM
  2. Need rs232 input file to osai ab 8600.
    By daldof in forum European Club House
    Last Post: 11-02-2012, 01:27 PM
  3. Osai A-B 8600
    By karmoleed in forum European Club House
    Last Post: 10-07-2012, 10:08 PM
  4. Osai 8600
    By SerHAs in forum European Club House
    Last Post: 07-06-2012, 01:44 PM
  5. Osai A-B 8600
    By Nebojsa011 in forum G-Code Programing
    Last Post: 01-07-2012, 02:10 PM
