586,104 active members*
3,449 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > BF20 style mill and boring head
    Oct 2009
    23
    So I just got a tts boring head. I have never used a boring head and I am not a machinist by any means. I understand that with the use of the boring head, as you move the boring bar farther from center it becomes more unbalanced. Is the proper way to use this with a bench top mill like a BF20 just to slow the spindle down to reduce the issues with balancing? Do they make something to offset this balancing problem with boring heads?
    Jun 2004
    822
    How big are the holes? I do mostly ~1" holes on mine and just keep the RPMs to 1000 or less and it's fine.
    Tormach has a couple good boring head basics videos.
    Hoss
    [ame=http://www.youtube.com/watch?v=jWVvX0lbN5E]Tormach - Boring Head Basics - Part 1 (ID) - YouTube[/ame]
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Oct 2009
    23
    I was just using it on a hole about an 1 in diameter to test it out.
    1943
    Quote Originally Posted by LLDesigns View Post
    They do make twin head boring bars that maintain balance. We used them a lot on VMC's where I used to work. They had 2 indexable inserts, one on each side. used mainly for roughing though.
    I have in the past put a rod hanging out of the opposite side to help with balance.
  1. BF20 style mill electronics
    By tkubic in forum Benchtop Machines
    Last Post: 07-04-2011, 07:54 PM
  2. Replies: 7
    Last Post: 04-25-2011, 03:02 PM
  3. Boring head on a TAIG mill
    By Hirudin in forum Taig Mills / Lathes
    Last Post: 05-25-2009, 08:18 PM
  4. BF20 Style cnc kit available
    By sgman in forum Benchtop Machines
    Last Post: 03-18-2009, 02:32 AM
  5. who makes a good boring head for x2 mill
    By mopar92 in forum Benchtop Machines
    Last Post: 01-11-2008, 06:10 PM
