586,035 active members*
3,797 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Huanyang 2.2kw VFD PWM Mach3
Results 1 to 1 of 1
    Feb 2009
    Smile Huanyang 2.2kw VFD PWM Mach3
    Before I start hooking things up and burning things, I decided to check with you guys if you can provide some tips and help. I would also like to make a visual documentation to help people like me in dire with their CNC hobbies.
    I recently purchased Huanyang 2.2kw VFD with its corresponding spindle.
    As an added benefit, I also wanted Mach3 to control the speed of the VFD.
    Searching the net and ebay I stumbled across PWM: PWM Signal to DC Voltage Conversion Board for Speed Control of Spindle CM112 New | eBay
    I also have this BOB:
    CNC 6 Axis DB25 Breakout Board Interface Adapter Mach3 KCAM4 EMC2 DB25 Cable | eBay
    My question would be: How do I wire "hook up" wires from BOB to PWM and PWM to VFD?
    Has anyone got this particular PWM?
  1. Connecting Huanyang VFD to Mach3 via Gecko 540
    By Vaffel in forum Spindles / VFD
    Last Post: 01-07-2015, 10:51 PM
  2. What size Pot for a 2.2Kw Huanyang
    By uspl in forum Phase Converters
    Last Post: 07-23-2012, 09:33 AM
  3. huanyang; a different question!
    By Mocha in forum Phase Converters
    Last Post: 03-21-2012, 09:55 AM
  4. Using a Huanyang VFD 3HP 2.2KW 10A with a 3hp 1500rpm FAN?
    By dkGoodrich.com in forum Phase Converters
    Last Post: 02-07-2012, 05:00 AM
  5. Huanyang HY02D223B goes POP!
    By stevespo in forum Phase Converters
    Last Post: 09-26-2009, 08:12 PM
