586,058 active members*
4,549 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > surface model vs Solid model machining
    Feb 2011
    Hi Cnczone followers.
    I'm currently thinking of changing CAM software.
    I've mastercam V4 at the minute which machines surfaces.
    Thinking of going to Delcam.
    I do alot of fine detail work with mastercam through machining surfaces.
    People are telling me machining surfaces is a think of the past.
    I guess what i'm asking is, has anyone recently made the change from machining surfaces to machining solids?
    is there any advantages to going in that direction?
    May 2004
    4519
    I don't get the question. Solids have surfaces. The surfaces of the solids are what are selected for machining. MasterCam already can do this.
    Feb 2011
    Mastercam generally works in surface models.
    Your part is a series of individual surfaces.
    For example, a cube with 6 sides has 6 independant surfaces.
    The likes of delcam works in solids.
    Import a cube and it comes in as 1 complete solid piece, or 1 surface.
    May 2004
    4519
    Maybe you are missing out on how to turn of the surface selection option when creating a tool path when working with solid models?
    Apr 2004
    12
    surfaces are just that
    solids are not so they are based on features
    a cube for instance would not be six surfaces
    but one extruded feature
  1. Solid Model
    By woodr004 in forum Uncategorised CAM Discussion
    Last Post: 07-24-2012, 03:01 AM
  2. RFQ need solid model of a hook
    By cloud chaser in forum RFQ (Request for Quote)
    Last Post: 06-20-2011, 04:12 AM
  3. Drawing onto a Solid Model
    By mcmachining in forum BobCad-Cam
    Last Post: 07-30-2009, 07:15 PM
  4. Looking for a solid model mazak e 410
    By psaudio in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-05-2008, 05:11 PM
  5. cutting solid model
    By mikejkd in forum Rhino 3D
    Last Post: 07-05-2005, 02:26 AM
