A Little more info about my problem
I was able to change the values of the coordinations, With "Reset" not blinking. im guessing this will allow the port to give numbers when i press the arrow keys.
CNC Electronics 5 -Testing the Parellel Port.wmv - YouTube
I tried to do the same thing here, but with 7,4,3 pins as thats the one assigned on my driver.
But for some reason, what ever i do it will stay on 3.3v voltage.
Im guessing this is a big problem
My ports are selected on mach, double checked the adress and stuff, i went to the artsoft website and watched the fist 2 tutorial videos.
Also.
When i plug in the stepper motors without the parallel port its quiet.
But when i power it with the parallel port to the driver and PC, it makes very annoying high frequency sounds, and the motors are twitching from time to time.
I was able to run a g code sample from the mach folder,
I can see the tool path. but when i plug in the driver and motors it wont do anything it will just do the noises.
PS, Every new move i try i always close the program and restart it, also, all of this problems were encountered while the driver was powered.
:idea::idea::idea::idea:
