586,036 active members*
3,813 visitors online*
Results 1 to 6 of 6
    Nov 2012
    g-code cycle not start
    Hi i have tb6560 cnc card from ebay. I installed mach3 program and connect tb6560 setup the pin ect. And I pressed the reset and start cycle button. but g-code not started... i can't find problem.... Please help me ....
    Sep 2011
    32
    Can you manually jog the axes using the arrow keys?
    Nov 2012
    no jog. does not working. may be my paralel prot is not working?
    Sep 2011
    32
    Did you run the driver test on Mach3? Have you set up the ports and pins in Mach3 set up per the instructions for the controller? Is your e-stop circuit working correctly and set up properly in Mach3?
    Nov 2012
    Quote Originally Posted by dsnaith View Post
    today i changed parallel prot settings on bios. Now paralell port mode ECP. but does not work.
    I dont run driver test how do i start? yes i set up ports(port name 0x378) and pins.
    Sep 2011
    32
    You need to carefully read and understand the Mach3 installation manual (http://www.machsupport.com/docs/Mach...all_Config.pdf). The setup of Mach3 is not intuitive, you need to follow the instructions. Once it is installed, you need to run the driver test program to make sure the software can communicate with the parallel port. Then you need to set up the ports and pins for your controller in the Mach3 config menu. If it is still not working, you need to start troubleshooting your hardware and wiring. It can be a long process... good luck!
  1. Mazak QT35N T2 Cycle Start
    By beto81 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2011, 07:56 PM
  2. Fanuc O-TT cycle start not working?
    By BryCAM in forum Fanuc
    Last Post: 06-05-2010, 11:20 AM
  3. Remote cycle start
    By REVCAM_Bob in forum Fanuc
    Last Post: 03-19-2007, 01:08 AM
  4. Remote cycle start?
    Last Post: 01-20-2007, 05:59 PM
  5. Cycle Start button
    By kaleem1 in forum Mach Software (ArtSoft software)
    Last Post: 12-24-2005, 09:05 PM
