I have Bobcad V24 with bobart, but no edm license.
Does anyone have any experience using EDM wire for a foam cutter?
Currently I;m using a program called foamworks, but it’s a little clunky adjusting the profile for the distance between the towers. My work flow is DEVCAD to cut the dxf files into equal segments, then Foamworks to generate G-code, the predator editor to use the math functions to move scale the axis and center the axis.
I can skip devcad and just use bobcad to equalize the spline now that I read a tip from Burr in another thread.
I plan on visiting the Bobcad booth at the PRI show in Orlando in a couple of weeks, so I hope they have someone that can run wire.
