586,076 active members*
3,783 visitors online*
Results 1 to 9 of 9
    Nov 2006
    473
    Torch height controller for oxy fuel
    I finally have my flame cutter working and making money with it. So now it is time to make it better
    I was looking on the cnc4pc website and found a capacitive torch height controller for oxy fuel and plasma torches. Has anyone used one? Do they work?
    Steve
    May 2010
    25
    I went into a dedicated oxy cutting facility last week They cut 100 ton per day) and they didn't have a THC on a machine that I was watching. It was about 20x60ft in length and was cutting 300mm MS.
    In terms of material thickness when is it critical to have a THC when oxy cutting?
    I would be interested in these if people have any experiences:
    Information on either the Hypertherm THC
    Sensor OHC (Oxygen Height Control) | Hypertherm
    or
    Capacitive Sensor
    Nov 2006
    473
    My problem is the slag buildup on the slats. The plates that I cut are usually 4 x 8 or 5 x 10, And 1 good chunk under the plates will raise a corner of a 1/4 inch or more.
    Steve
    Apr 2006
    54
    Quote Originally Posted by scrambled View Post
    Steve
    Hello Steve,
    Agelkom's (@cnc4c) capacitive height controller is suitable for your application.
    Also Techserv (in UK) use this sensor for their multi head flame cutters.
    Pictures attached.
    Best regards,
    Can
    Nov 2006
    473
    Agelkom -
    Does your controller work when cutting around cut outs or holes?
    I am very interested in learning more about this torch height controller
    Steve
    Apr 2006
    54
    Agelkom -
    Steve
    Hi Steve,
    Yes, it works for both. Please look
    Capacitive Sensor and view Edge Cutting Test video
    Best regards,
    Can
    Sep 2005
    1195
    Re: Torch height controller for oxy fuel
    Hi Steve,
    Do you use THC to cut steel plate with oxy/acetylene?
    Mar 2013
    156
    No. Right now I have to manually adjust the torch height using the up and down buttons.
    Steve
    Sep 2005
    1195
    You flame cutter has 3 hoses or 2 hoses? I have victor with 2 hoses. Do you think this 2 hoses flame cutter good enough for piercing? I have not tried it yet.
  1. Torch height controller
    By shane w in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 02-08-2014, 02:23 PM
  2. Torch height controller(THC) for YAG laser
    By larryy1022 in forum News Announcements
    Last Post: 01-15-2012, 02:34 PM
  3. new arc voltage torch height controller for 2011
    Last Post: 03-08-2011, 04:17 AM
  4. Torchmate, Torch height controller, problem?
    By stevensea in forum Torchmate
    Last Post: 04-16-2009, 12:29 AM
