I've had my Series III machine for about a month, and today I noticed a "ticking" noise in the Spindle as if something is just knicking the spindle while it's rotating. I removed the PDB, removed the belt and ran the motor only at about 1000 RPMs with no issues. Then reconnected the belt, removed the drawbar and ran just the spindle and there is a noticeable "tick" between 800 and 1000 RPMs. So the noise is definitely coming from the spindle as all other hardware was removed. Any idea what might be making this ticking noise? I would think bearings would just create a high pitched squeal.
I have also had an issue with larger BN mills causing a lot of shaking in the machine. This is what led me to start looking at the spindle to see if there was a problem there. I have a 2F 5/8" HSS BN that I run at 2000RPM and 24 IPM .05"DOC. Makes nice cuts but sounds like the whole machine is shaking apart. I will probably slow this down even though I would think the machine should be able to handle it. There are several other things like drilled hole diameter that are making me take a closer look at the spindle. I even tried another drawbar thinking it might be bent for some reason, but no change.
