I have only cut hot rolled steel on my table .will cold rold cut the same with the same settings and is it hugely more expensive
I need to attach 5/8 letters to 5/8 plate I thought I would epoxy then drive split pins though the letters and weld over the ends as this needs to be powder coated and I want to avoid rust runing out from between the parts.
I thought cold rold mite be a cleener sufacebut mybe sand blasting hot rold mite be the way to go
Any thoughts ?
