Hmm okay so if i was okay with going with lower speeds, i could potentially cut aluminum (like 1/8") - right?
[That really depends on the machine you get, but it's more about rigidity and runout than about speeds.]
Right now i'm looking at then Zenbot 2424 and the Fireball X90. The X90 is a little too small for my needs but shouldn't i be able to reclamp the material in another position and sort of "start over"?
[That's possible, I suppose, but it's not easy, especially if you want accurate results.]
I realize the precision will be dependent on my clamping skills, but i assume that with training it shouldn't be that hard, no?
[You not only have to have good "clamping skills", but you'd need to break up your CAM programs into multiple parts with multiple zero points, and somehow get one to take up where the other left off. Who's going to train you to do that?]
I was also looking at the Bluechick, but read that perhaps the construction of that one isn't really sturdy enough for what i want to do.. Any thoughts on this? I'm def. upping my budget to at least $2k
